need help on how to input the syntacs
Hello everyone.
I am a newbie on using COMSOL.
I would like to ask from someone who knows how to input the syntacs a command in COMSOL 3.5.
Right at the moment i am doing a study diffusion of moisture into a semi porous solid media and based on my literature reviews the diffusion coefficient of this semi porous solid media is dependent on temperature.
i have tried inputting the equation
Deff = 9.60 exp(-(4109.6/273+C))
It is the Deff that i would like to input as a function of Tenperature in Celsius represented by the variable C.
but an error occurs that tells me below as
Exception:
com.femlab.util.FlException: Syntax error in expression
- Expression: -9.60exp(-(4109.6/273+C)
- Variable: D_c_di
- Description: Diffusion coefficient c
- Subdomain: [1]
what i would like to ask if somebody could help me out how to input the syntax of this equation into the diffusion coefficient.
Thank you so much in advance for reading and the help extended.
god bless you.
Jonathan
3 Replies Last Post 10 lug 2010, 11:33 GMT-4
Posted: 1 decade ago 28 giu 2010, 03:12 GMT-4
what if you try
Deff = 9.60 * exp(-(4109.6/273+C))
with an explicit " * " for the multiplication ?
Hi what if you try Deff = 9.60 * exp(-(4109.6/273+C)) with an explicit " * " for the multiplication ? Ivar
Posted: 1 decade ago 6 lug 2010, 04:28 GMT-4
how to give a Sine wave input to a port.
when typed "4*sin(pi*t)" with time varying from 0 to 2 in steps of 0.2.........
its showing an error of non defined constant.
cAN you please tell me how to give an AC input to a port ?
how to give a Sine wave input to a port. when typed "4*sin(pi*t)" with time varying from 0 to 2 in steps of 0.2......... its showing an error of non defined constant. cAN you please tell me how to give an AC input to a port ?
Posted: 1 decade ago 10 lug 2010, 11:33 GMT-4
First "t" for time is only valid in transient solver mode (else t=0 in V4 at least).
Now, normally if you have a sinus excitation you are in the "harmonic load case" and you do a development of the equations in the harmonic weay, then you define mainly the amplitude and the frequency (or omega w=2*pi*freq check your application mode / physics) .
By changing frm static to transient to harmonic mode you change the equations somewhat too, see the v3.5a "Physics - Equation setting s ..." or better look it up in the doc
Have fun Comsoling
Hi First "t" for time is only valid in transient solver mode (else t=0 in V4 at least). Now, normally if you have a sinus excitation you are in the "harmonic load case" and you do a development of the equations in the harmonic weay, then you define mainly the amplitude and the frequency (or omega w=2*pi*freq check your application mode / physics) . By changing frm static to transient to harmonic mode you change the equations somewhat too, see the v3.5a "Physics - Equation setting s ..." or better look it up in the doc Have fun Comsoling Ivar
