error message
??? Java exception occurred:
Exception:
com.femlab.jni.FlNativeException: Failed to evaluate variable jacobian
- Variable: gamma
- Geometry: 1
- Subdomains: 1,2,4,5
Stack trace:
at xevalutil.cpp, row 2862, ()
at com.femlab.solver.FlSolver.assemble(Native Method)
at com.femlab.solver.Assemble.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.server.q.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
Error in ==> femsolver at 368
solobj.smartRunner(report, loopTime);
Error in ==> assemble at 60
varargout = femsolver(mfilename,'Assemble',fem,varargin{:});
Error in ==> N_S_ole at 59
L = assemble(fem,'Out',{'L'});
Thank you, I need your help!
1 Reply Last Post 7 mar 2011, 00:31 GMT-5
Hello Zhiyong Si
Posted: 1 decade ago 7 mar 2011, 00:31 GMT-5
March 7, 2011 5:31am GMT
Are you able to find the error
I am also facing the same problem.
- Variable: gamma
- Geometry: 1
Please let me know, if you have found the solution.
Praveen
March 7, 2011 5:31am GMT Are you able to find the error Hi, I am also facing the same problem. Failed to evaluate variable jacobian - Variable: gamma - Geometry: 1 - Subdomains: 1,2,4,5 Please let me know, if you have found the solution. Regards, Praveen
