18 set 2010, 10:29 GMT-4
I've often seen (both in COMSOL doc as well as on this forum) codes like the one below (just a sample).
p = (peaks+7)*5;
figure
image(p)
v = axis;
c = flim2curve(p,{[],[5:5:75]});
g = geomcsg({rect2(5,45,0,50)},{c});
s = solid2(g);
I believe these should be typed out at some command prompt, but where, I have no idea. Could somebody please shed some light on this. I need to use the function "flim2curve" on a COMSOL result after post processing to create geometries.
Thanks in advance,
Harish
These are matlab codes, which you can run in combination with Comsol. Try searching for matlab in the documentation or here.
[QUOTE]
p = (peaks+7)*5;
figure
image(p)
v = axis;
s = solid2(g);
Thanks in advance,
Harish
[/QUOTE]
18 set 2010, 10:40 GMT-4
Thanks Danial.
I tried running COMSOL with MATLAB. At first it couldn't find MATLAB installed in it at all. Later I updated the COMSOL.opt file to read the MATLAB root directory.
Now when I try opening MATLAB from COMSOL, it opens it successfully but I get the following msg in MATLAB
' ??? Undefined function or method 'comsolmexpath' for input
arguments of type 'char'.
A few minutes later, COMSOL pops up a msg saying timed out.....
Any Idea on how could I setup up the link correctly?
Harish
Thanks Danial.
Harish
19 set 2010, 05:16 GMT-4
Looks like yopur path link matlab COMSOL is not fully set-up, have you checked the KB ? there are a few reports about how to check maually these settings
20 set 2010, 10:03 GMT-4
I had the same problem. You have to reinstall Comsol by correctly specifing the Matlab directory from the beginning. This will add a folder in the Matlab directory, where Comsol will put its own files.
Alois
Alois
